Sujets : 0
RE: Pavillons et maths
Many thanks,
my french is not good enough to answer in french.
Not to be a little off-topic but what has a horn to do with an excellent baguette and i know that in your country there are many experts concerning this topic
For a good baguette you need a long cold dough process and patience and care with the product to get these results:
My capabilities have improved also here.
A good horn imho must be long enough to provide excellent loading. But traditional horns with good loading often suffer of beaming. I have optimized the profile as much as possible with natural dispersion but i think it cannot be made significantly better. These results are near the optimum. While the horizontal dispersion is about 60 degrees it is not possible imo to get the samne result for the vertical. But about 30 degrees is more than enough when placed above a bass cabinet. With the 1in4 horn even a two way speaker is possible with modern compression drivers.
Sujets : 69
C'est très intéressant ... je vois bien ces pavillons pour charger mes Onken OS500 et faire un système simple en 3 voies ...
Sujets : 50
(22/09/2022-11:27:00)drba a écrit : Many thanks,
Not to be a little off-topic but what has a horn to do with an excellent baguette and i know that in your country there are many experts concerning this topic ?
Haha great, am myself training hard on pizza dough with me newly built wood oven
Another discipline compared to horns
Sujets : 82
(22/09/2022-16:29:34)nicolasd a écrit : C'est très intéressant ... je vois bien ces pavillons pour charger mes Onken OS500 et faire un système simple en 3 voies ...
Honnêtement Nicolas, passe directement à des grands pavillons, c’est un autre monde, rien de comparable même à des iwata ou des multicellulaires, enfin si tu as la place !
Sujets : 69
(23/09/2022-13:37:18)Bamboufou a écrit : Honnêtement Nicolas, passe directement à des grands pavillons, c’est un autre monde, rien de comparable même à des iwata ou des multicellulaires, enfin si tu as la place !
J'en suis bien conscient, mais pour ce qui est de la place c'est pas gagné ... si déjà j'arrive à installer correctement mon système actuel (ou approchant) dans mon futur logement ça sera pas mal ... et comme je ne suis pas super branché par les pièces dédiée, ou seulement si elles communiquent avec le séjour principal, cela demande donc un max de surface au rdc ... les longères en RP sont plutôt rares ... ;o)
Sujets : 49
(23/09/2022-13:37:18)Bamboufou a écrit : (22/09/2022-16:29:34)nicolasd a écrit : C'est très intéressant ... je vois bien ces pavillons pour charger mes Onken OS500 et faire un système simple en 3 voies ...
Enfin tu voulais dire "même à des iwata ou des multicellulaires
petits". Tu as raison !
LB
Sujets : 82
(23/09/2022-14:36:17)nicolasd a écrit : (23/09/2022-13:37:18)Bamboufou a écrit : Honnêtement Nicolas, passe directement à des grands pavillons, c’est un autre monde, rien de comparable même à des iwata ou des multicellulaires, enfin si tu as la place !
Je comprends bien, la pièce est bien un maillon essentiel dans un système a grand pavillon, avec des pièces plus petites il faut se restreindre sur les dimensions du système, mais hélas avec les limites que cela apporte sur les écoutes !
Je n’aime pas trop les pièces dédiées, je tenais à intégrer mon système dans mon salon, je pense que c’est pas trop mal réussi, en tout cas sur le résultat acoustique ça fonctionne parfaitement !
Sujets : 0
Hi,
I would like to just mention that I added a splines export feature to the JMLC worksheet. Some CAD programs can work more efficient with splines import and especially Fusion for which I also provide the corresponding Pythion scripts. Enjoy.
https://sphericalhorns.net/2022/12/20/ex...worksheet/
Sujets : 0
10/04/2023-13:00:50
(Modification du message : 10/04/2023-13:03:08 par drba.)
Hi,
I would like to point the attention to my new fin horn design which is free for use:
https://sphericalhorns.net/2023/04/09/th...-fin-horn/
Sujets : 50
Hi drba
Thank you for letting us know, incredible collective work you have been doing with colleagues !
Jean-Louis
