Fitre passif 2 voies - 600hz
#21
RE: Fitre passif 2 voies - 600hz
bonjour stéphane
effectivement ,il y a eu du changement
c'est un lecteur sony pro?
bonne journée
Bonjour Claude,
Oui le Sony CDP-3100 est un lecteur pro, datant des année 90 (il était encore dans la catalogue Broadcast de 99), bizarrement un peu long a trouver la table des matières des disques, convertisseur en 18 bit (personnellement je l'utilise en drive).
Les caracteristiques :
CD Player System
CDP-3100/CDS-3100
,ĢFront loading and highly compact CD player
,ĢTwo units can be mounted in a 19-inch rack
,ĢFully featured remote control, including jog dial for
comprehensive control in on air and production
applications
,ĢAES/EBU digital and balanced XLR analog outputs
,ƒ¢Variable speed playback in a range of ¨±12.5% in 0.1%
steps
Supplied Accessories
CDP-3100 CD Player
AC power cord (x 1)
Operation manual (x 1)
CDS-3100 Remote Controller
Connecting cord (2 m, x 1)
CDP-3100 Rear Panel
Optional Accessories
DABK-3101
Memory Board
,Ģ Provides memory cueing and
instant start
DABK-3102
Interface Board
,Ģ Provides sampling rate
conversion (38 to 50 kHz)
,Ģ Synchronizes to an external video
reference, word clock or D/I sync
,Ģ 9-pin serial remote control
Specifications (CDP-3100)
Number of Channels: 2 channels (stereo)
Readout System: Non-contact optical system using semiconductor
laser pick-up
Laser: GaAIAs double hetero junction diode with 780 m
wavelength
Rotational Speed: Between approx. 200 rpm (outer circumference)
and 500 rpm (inner circumference)
Error Correction: Sony super strategy cross Interleave Reed
Solomon Code (CIRC)
D/A Conversion: 18-bit 8 times oversampling
Frequency Response: 20 to 20,000 Hz +0.5/-1.0 dB
Harmonic Distortion: Less than 0.01%
Wow and Flutter: Below measurable limit
Signal-to-noise Ratio: More than 92 dB
Crosstalk: Less than -80 dB at 20 kHz
Variable Speed Range: ¨±12.5%
Outputs
LINE OUT: Balanced, XLR-3-32 type (x 2), nominal
+4 dBu (600 ¨?), maximum +19 dBu (600 ¨?)
MONITOR OUT: Unbalanced (x 2), nominal -10 dBu (47 k¨?)
maximum +5 dBu (47 ¨?)
DIGITAL OUT: AES/EBU, XLR-3-32 (x 1)
HEADPHONE OUT: Maximum 0 dBu (32 ¨?)
Remote Control I/F: DIN 8-pin for fader start control, 10-pin for
CDS-3100
Power Requirements: AC 100, 120, 220 to 230, 240 V, 50/60 Hz
Power Consumption: 35 W
Dimensions: 212 (W) x 118 (H) x 408 (D) mm
(8 1/3 x 4 3/4 x 16 1/8 inches)
Mass: 6.5 kg (14 lb 5 oz)
Stéphane
Club double 16"
Demande de conseil pour rajouter un tweeter filtré a 6dB, 2 solutions :
-Je part du bornier d'arriver du filtre, je rajoute un L-Pad et un condo
-Je part du bornier du RCA MI-9472A http://4.bp.blogspot.com/_-i1wjkiEGro/Sa...000507.JPG (il abaisse déjà la compression) et je rajoute un condo (sachant que la compression et le tweeter sont donnée pour le même rendement sur les specs)
Votre avis
Stéphane
Club double 16"
Salut Stéphane,
Moi, j'essaierais de reprendre sur l'autoformer, si toutefois il est branché dans le bon sens... Wink
La seule réserve c'est que la partie en série de la bobine va te couper les hautes fréquences... C'est donc à voir selon la valeur d'induction. A priori avec ces gros transfo, ça doit passer...
Pas de L-Pad, sauf pour les réglages, c'est très mauvais. Il vaut mieux souder deux résistance ''série - parallèle'', de la valeur choisie pour l'atténuation, et calibrées pour faire au total 8 Ohms (Ou 16 selon le tweeter).
bonsoir stéphane
Qui est le constucteur de votre auto-transformateur 15 prises
Régis
Bonjour Régis,
J'ai acheter cette auto-transformateur 15 prises ici : http://shop.ebay.fr/merchant/mast_mutter
Stéphane
Club double 16"
Stéphane,
Tu as déjà payé ?
C'est ballot, j'en ai aussi une paire que je n'utilise plus, j'aurai pu te les prêter / vendre / donner.
Bonjour julien,
Si tu lie le post au dessus ce n'est pas moi qui en cherche une paire c'est Régis.
Moi aussi, il m'en reste une paire, celle que j'utilisai avant d'utiliser les RCA.
Stéphane
Club double 16"
Bonjours a tous, j'utilise les transfos de Stéphane depuis plus de 6 mois sur des VOT avec le schéma du constructeur .L'alignement " à l'oreille" des HP:moteur + HP grave presque sur le même plan (pas d'instruments de mesure) semble confirmer qu'il s'agit bien d'un filtre du 2¨?ordre comme pour les coax Tannoy.
Cdlt
Régis.
bonjour a tous
mon mien :
http://www.elektor.fr/forum/forum/realis...1244.lynkx
que je vais refaire un de ces quatre...
bonne journée
