Compression 18sound en Be
#51
RE: Compression 18sound en Be
Hello drba,
(16/12/2025-13:10:40)drba a écrit : (...)
I also commented that the TH4003 is imo a not good performing device wrt to high end sound quality. neither the acoustic loading nor the directively control properties are acceptable wrt to modern high end requirements.
I agree to disagree with those words. The TH-4003 is imho a very capable and very good performing horn. Dispensing a high end sound quality when matched with a good driver (but this depends also on the xover schematic), TD-4002, TD-4003,18s 4015Be ...
Directivity measurements on it (when done correctly ...) proven a very good behaviour in Horizontal Response, often unmatched even with more recent designs.
The special vertical directivity is best exploited with inwall mounting where the speaker is placed high and oriented slightly leaning towards the mixing console (BTW the xover will have to be temporally adjusted from the listener's placement). (wrt what you wrote)
Best regards,
n.
https://sphericalhorns.net/2024/07/05/a-...inema-horn
