Mélaudia in Marciac 2021
Toption Instrument Co.,Ltd.
Toption Instrument Co.,Ltd. is a professional laboratory solution provider. Headquartered in Xi'an, China, TOPTION has hundreds of universities and research institutions, and is famous for its thousands of years of long history and culture. TOPTION is committed to providing reliable extraction, distillation, purification and concentration solutions and products for global customers engaged in chemistry, biology, pharmaceuticals, food, environmental analysis, academic research and other fields.
The centrifugal extractor is a new type of liquid-liquid extraction and separation equipment, which is fundamentally different from the traditional extraction equipment such as mixing settlers in principle. It uses a motor to drive a high-speed rotating drum. Under the conditions of the shear force generated by the rotation of the drum or blades, two different densities and immiscible liquids are mixed and transferred. And the centrifugal force generated by the high-speed rotation of the bowl is quickly separated. Centrifugal extractor has the advantages of fast and efficient. Our Cbd Centrifugal Extractor and Hemp Extraction Centrifuge have high extraction rate, high alcohol removal rate and good low temperature grade. They are all fully automatic design, convenient maaterial loading and unloading, can be completed by a single person, saving labor costs.
https://www.toptiontech.com/
RE: Toption Instrument Co.,Ltd.
PUB ?
Lecteur CD STUDER A730 - Tuner PHILIPS 22AH6731 - AMPLIS - WE300B  - K209+ Grand_Floyd  option tantale/argent - LE CUBE - Platine THORENS TD318 + cellule PHILIPS  GP422 et stylet taille Shibata + RIAA PACIFIC - Enceintes AUDIOREFERENCE 224.- Câbles ISODA partout.
Bonjour Christian,
Oui, et le coin des pros c'est l'endroit où ils peuvent poster.
J'ai hésité à simplement supprimer le message, mais il y avait de belles images alors j'ai laissé.
D'ailleurs, c'est pas toi qui l'a attiré ? en allant chercher des transistors en Chine ;o?
Bonjour Raoul,
Je n'achète plus de transistor en Chine depuis un bon moment (chat échaudé craint l'eau froide).
Christian.
