Kits Kaneda
RE: Kits Kaneda
Voilà le schéma du Kaneda No.297 :
RE: Kits Kaneda
(10/03/2025-16:37:15)didierS a écrit : Bonjour,
avec les photos en plus .....
RE: Kits Kaneda
Voici la conclusion de l'article au sujet de ce n° 297 :  " Son de l'ampli "
This time, we listened to mainly symphonies by Brückner, Rachmaninoff, and Shostakovich using the Onken + Altec three-way network system.
This unit has the power to express performances in detail.
It has a strong resonance and vividly reproduces the performers' heartfelt performance. It accurately expresses the tone and performance of each part, and at the same time, it has a strong ability to reproduce the sounds that blend together in the space as overwhelming sound pressure.
The sounds are not simply physical, but seem to be living creatures full of emotion. Even though I know what the music will be like next, I still feel anxious and excited every time I hear it. In Bruckner, the contrast between strings and brass instruments is beautifully reproduced, and the woodwind melodies that alternate one after another float in the space. In Rachmaninoff's later years, emotions of anger and impatience explode like the wind. Shostakovich's mysterious movements are like the arrival of a world that seems not of this world.
As always, even when trying to calmly evaluate the sound, one is inevitably drawn in by the sound. Conversely, the stronger the power of the amplifier to draw one in, the closer it is to the goal of being a music reproduction amplifier.
This unit is clearly an amplifier that has come several steps closer to that goal.
RE: Kits Kaneda
Merci à vous deux pour ces infos.
On voit effectivement que le volume est maintenant réglé à l’entrée de l’ampli, et non plus par le changement de valeur de la contre-réaction, celle-ci étant désormais fixe, ce qui procure un fonctionnement plus stable.
Cela explique aussi le nouveau schéma de filtre pour la multi-amplification No.293. En effet, Kaneda a dû modifier l’ancien filtre pour s’adapter à ce nouveau type d’entrée d’amplificateur, avec l’obligation d’avoir un buffer devant chacun d’eux, sans compter l’abandon ( momentané ?) de l’adaptation d’impédance en courant, ou IVC.
RE: Kits Kaneda
Ce 297 m’attire …
Merci à tous pour la doc.
Gilles :-)
RE: Kits Kaneda
RE: Kits Kaneda
(10/03/2025-16:28:17)gillesni a écrit : Jean René,
Ce n'est pas pour tout de suite, mais je remonte voir Jean H. comme prévu d'ici l'été, je ferai mon possible pour faire une halte chez toi, d'autant que ça m'intéresse de réécouter tes panneaux dans leur milieu habituel.
Bonjour Gilles,
OK, ça marche ... on pourra peut-être se faire une p'tite bouffe .
Je pars en vacances 2è quinzaine de Juillet.
belle soirée
JR
RE: Kits Kaneda
Entendu Jean René,
On en reparlera.
RE: Kits Kaneda
Coucou,
Retour de quelques "magnifiques" FAUX transistors Nec 2SD218 dans des ventes aux enchères au Japon :
On voit nettement les traces de brossage qui ont permis d'effacer les références originales. Pas très doué celui qui a fait ça ; beaucoup moins brillant que ne le sont les boîtiers.
RE: Kits Kaneda
J'ai ouï dire que sur les vrais les uns ressemblent à un l et non un 1
[Image: 2sd21810.jpg]
Utilisateur(s) parcourant ce sujet : 30 visiteur(s)
