A Note about CD Loudness (by Cohearent Audio, LLC)
Cohearent Audio is known for vinyl but also does lots of CD mastering. We would be happy to master your CD, but need to make one point very clear: We refuse to compress CDs to the degree known as “current industry standard”. Most CDs are mastered today with 6 to 8 dB or more digital compression, over and above any compression done in the original recording, just to make them loud, and the same loudness as every other current CD. We have been vehemently against this practice since it started in the mid 1990s.
It started with Rap and Dance music, and then filtered down to Pop music and now, even Jazz and Classical CDs. Once a few did it, everyone started doing it so their CDs wouldn’t sound quieter than the next guy’s. Many record labels started using 5 CD carousels to compare the 4 top selling CDs against a new one being submitted.  Now the criteria  is MP3s on Ipods and other current music storage devices.  If a new project isn’t as loud as everything else, it is sent back for “remastering”, READ: SQUASHING. This makes the sound annoying, fatiguing and unnatural. Many classic albums have been remastered this way, and when compared to the original releases the results are appalling. It is very simple to adjust your volume control to the desired volume when playing a CD. That way you are hearing the natural dynamics of the music, not slammed, all-one-volume drek. Why should the record labels be allowed to make this decision for you? If you don’t understand this, check out “The Loudness War” on You Tube… We are happy to use a bit of compression or limiting to “even-up” volumes between songs but we don’t SLAM. I have heard and read dozens of mastering engineers complain about this. We are doing something about it. If LOUD is what you are looking for, please just take it somewhere else!
https://www.cohearent.com/a-note-about-cd-loudness/
La compression de dynamique est un véritable fléau pour l'audiophile et est parfaitement à l'image de ce que "le monde moderne" est capable de pondre comme connerie !  Angry
Heureusement qu'il reste des gens intelligents...
Didier
RE: A Note about CD Loudness (by Cohearent Audio, LLC)
(11/09/2023-10:59:00)didierS a écrit : A Note about CD Loudness
Didier
Bonjour Didier,
C'est effectivement très intéressant et faudrait que ça fasse un cas d'école qui incite les autres ingénieurs de mastering à ne plus sonner fort.
Mais, malheureusement, c'est souvent le commanditaire qui décide, et il est difficile de ne pas suivre la volonté du client qui est aussi le payeur.
Mais, on ne peut que félicité cette initiative.
Bonne soirée
Oui, intéressant. j'ai regardé plusieurs interview de Kevin Gray et il en parle parfois.
Mais il faut noter qu'il représente actuellement ''la crème de la crème'' des ingénieur mastering. Il est très demandé, ''masterise'' près de 400 disques par an (!!) et bénéficie d'une réputation exceptionnelle dans le milieu.
Maintenant quasiment plus que Bernie Grundman.
Il grave des laques ''seulement'' 4 jours par semaine pour qu'elles partent en DHL/UPS immédiatement aux usines pour la galvanoplastie, et que les laques ne restent pas en rade pendant le week end.
Il faut dire qu'il a travaillé avec Doug Sax qui était, une génération en arrière, lui aussi une star du mastering et qui avait des résultats excellents.
Ce qui rejoint un peu notre passion et qui me semble intéressabnt, c'est que K.Gray a particulièrement de succès depuis qu'il a modifié son système de mastering. ce sont quand même des électroniques tout classe A à composant discret, ce qui n'est pas la règle dans le matos pro, même de qualité. Il y a un soin particulier porté aux appareils de la chaîne. Je ne me rend pas trop compte du ''poids'' que ça pèse dans le résultat final, mais j'imagine que logiquement c'est décisif.
Je note aussi les enceintes de monitoring DIY avec boomer JBL et médium aigu Dynaudio à dôme textile.
pour moi, à voir les diverses photos et reportages qui sont sur le net c'est un superbe studio qui n'a pas pas la changite des électroniques et encore moins des Enceintes Monitor.
Les monitors 4 voies et tri-amplifiées DIY du studio ont une bande passante de 12 à 30 000 Hertz ..... avec des 38cm.
Ils entendent tout et ne forment plus qu'un (Kevin Gray et son système).
Kevin Gray s'est constitué un véritable outil de travail abouti qui est au service de la Masterisation ......
Peut-on en dire autant avec les autres studios ?
on en revient à la sempiternelle question que tu sembles évoquer Ici:
Pourquoi et Comment un lieu d'écoute -si bien équipé soit-il- peut-il reproduire l'acoustique du lieu d'enregistrement et les choix du "gars au boutons"* ? Wink
*je ne parle pas d'un jeune boutonneux mais du gus qui à travers quelques potars et une "feuille musicale" doit faire passer une émotion...quelque soit le matos et le lieu...
