ALTEC Voix Du Théatre : Le Club des Vottistes
RE: ALTEC Voix Du Théatre : Le Club des Vottistes
Les Amis du Son a écrit :Mille excuses !
Nouvelle adresse mail :
lesamisduson@yahoo.fr
Ok, pas de problème, le principal c'est que nous puissions communiquer
A bientôt,
Lecteur CD: Sony SCD  777 ES
C'est ou et à quelle heure?
Non, je blague !
Bruno
Hello
Anybody used the original crossover ALTEC N800D 16 ohms?
I have four pieces. In all four, the capacitors are defective. They measure between 40 - about 100uF instead of 10.5 uF. In order to measure them properly, they must be unsoldered. I'm really amazed ... play now, WEST CAP Bathtub capacitors and fit perfectly into the original casing. The crossovers play again perfectly
Felix
felix a écrit :Hello
Hello Felix,
I used original crossovers with my VOTT. You are right some need to be recapped. But as soon as you start to make your own one, your VOTT will reach another world. The N800's are designed with efficiency in mind, but depending and how your particular components are sounding or aged the gain in smoothness will be amazing. Doing you own crossovers allows you to better tailor the frequency response for each components to get a more linear frequency response. Also don't forget, a VOTT in a movie theater differs from a VOTT used for hifi, I don't use my VOTT behind a screen.
I get +/- 5dB from 40Hz up to 20kHz with my home crossover comparing to +/-15dB within the same range with original xover. I can easily integrate a tweeter, I can linearize the impedance, I can over or under amortize a second order filter to equalize a bit a particular band. More play, more fun.
Best regards,
Hello PFB
Interesting what you write. I'll call you in the next days.
I wanted to reconstruct the system WE 555 with KS 12024 The Tube Vol.56 Kingdom, where Julien has translated perfectly. Ok, there it played with 803A and 12Ohm crossover.
My 803A is 16 ohms.
I also wanted to say that the vintage Altec crossovers on ebay, N800 or N500 Hz, tighten in the last time the prices.
All the more amazing, I dare say that many crossovers are defective and many do not realize it.
Best regards
Felix
bonjour à tous. Avé Altec...
une paire pour la hifi, une autre pour le cinéma.
dep 17
pascal.
[attachment=9093][attachment=9094]
Bienvenu Pascal !
C'est très chouette ! Les pavillons bois sont d'origine CH-Audio ou bien fabrication allemande ?
merci pour l’accueil, Dominique.
Les pavillons sont d'origine anglaise, avec en ce moment des compressions fostex.
pavillons a petit budget...je précise.
Je suis parti du principe, de me lancer un défi, et faire marcher ces pavillons.
rien n'est gagné , je commence a trouver des émotions plus qu'honorable
J'ai passé plusieurs heures à les rendre présentable, les poncer, enlever les surplus de colle, les surplus de silicone....et faire des essais.
(Les pavillon 511 sont mis de coté, équipé avec les compressions altec...) et restent prés de leur mére...
Plus le résultat prend forme, plus il me faut d'essais décevant, pour peu de progrès ...mais j'améliore doucement...
Dominique-Tanguy a écrit :Bienvenu Pascal !
il ne me semble pas etre des CH audio design.
Je possède une paire de CH1505BWLFull lobed de CH audio design et elles ne semble pas ressembler pas à ceux de Pascal.
A vous de juger avec les photos de mes pavillons
"elles ne semblent pas...." serait mieux
désolé pour la faute d'orthographe
