Onken Caprice
Onken Caprice
Je voulais simplement vous partager ma découverte d'une enceinte que certains connaissent peut-être déjà: la Onken Caprice:
http://www.planet-inc.co.jp/ONKEN-HP/tab-c1.html
Celle-ci a piqué ma curiosité en naviguant sur le site "Onken".
Voici ce qu'en dit le texte accompagnant les photos:
Caprice is the name that you gave from Rhapsody of Paganini. The virtuosity of the street Akkaruto of its name, tells without exhaustive. Violin fact that is good, other musical instruments and human voice is also a natural and I think that you know that you say that.
Midrange unit of this system is the driver of 845ES type 1 inches throat. Since it Toritsuki to other Altec 811B and 511B horn of Oncken horn, it can be measured also greenhouse grade up using the 845ES to the system of Altec.
The Caprice, I responsible for the 8000Hz from 800Hz. 845ES also 455ES Similarly, vibration system, sound quality because it is Mylar edge is a natural.
Enkuroja of Caprice, 38 but as for centimeters is relatively small, two twin unbelievable such from the duct, the quality of the bass is played. Duct from changes also sound a change of 1 mm, accuracy is required.
As a variation of the parts of the Caprice, horn I can also be used in the 811B type of Altec. As an LC network also 12 digital oct 6 digital oct, it can be low-cost simplified. But 6 digital oct consists way of sound, different from the sound image such as 12 digital oct.
I think evaluation is divided depending on how listening music. Although it is my opinion, the latter sense of depth and to the sound person, charm that can not be the words of like plaintive sense of music, there are differences in taste but is a matter of taste all sorts. Also driving in a multi-amplifier, you can also use it to leverage the performance of the unit enough. However, it would be the network Given the ease of daily life.
4 VOIES
Sound absorption of enclosures includes a socket felt of 10 mm, it is a combination of SC40 type of malt plane.
Power amplifier for driving, in the case of the Tube with output transformer, the performance of the amplifier because it is exhibited in a 16-ohm terminal, the woofer uses a 16-ohm 416A.
When the drive amplifier of DC amplifier and OTL amplifier, even 416A, also available in an 8-ohm 416-8A.
Caprice, taste also also fresh comfortably up the volume to, you enough to hear Gotae can be obtained even squeeze the sound.
The room is also not special, and we want will enjoy casually the music is placed in the living room.
Prices will become more expensive, but is a combination real parts of the highest quality. Well, box thing too a simple look at the during the open the lid, you can surprise in safety building. Also it will waning confidence in the sound. So, also it will faded satisfaction in something like bought appearance.
Caprice is, apparently, but would There are various impressions also purchased, in a speaker that can be of that mingle deeply life, I think I would like to have to pull out the potential and its ability to fully.
Est-ce que certains ont déjà vu/entendu cette enceinte?
RE: Onken Caprice
Bonjour Sébastien
Google translation ?
RE: Onken Caprice
Bonjour Sébastien,
Voici un article paru dans la Nouvelle Revue Du Son n°219 en mai 1998 :
RE: Onken Caprice
Merci Dominique, on pourra remarquer une chose, cette enceinte est dans l'esprit de la Nineteen Altec mais avec tweeter et remarquez l'accord de l'enceinte de 235 L contre 225 pour l' Altec, les évents rectangulaires sont au nombre de deux donc mis bout à bout sont un peu plus longs que ceux de la 19 mais profondeur de 25 à 30cms, 1,9cms pour la 19, tout cela pour dire que l'accord du BR de la 19 n'est pas bon, ce que j'avais constaté en le prolongeant, tout ca pour dire que la 19 esr redoutable apres quelques modif, pas tres loin de cette Onken je pense. Désolé, je suis un peu hors sujet.
RE: Onken Caprice
pvrx a écrit :Bonjour Sébastien
Oui, oui, sans retouche, simplement pour ne pas qu'avoir du japonais à se mettre sous la dent. Wink
Dominique a écrit :Bonjour Sébastien,
Dominique, génial cet article! J'ai bien apprécié voir les croquis de M. Koïzumi, ainsi que son petit atelier à Tokyo.
RE: Onken Caprice
Sébastien,
Tu sembles prêt pour te chercher des Onken.
Cool
Voici un article de Jean Hiraga de 1976. C'est sans doute le ou un des tout premiers articles qui ont fait connaitre ces HP hors du Japon pour la 1ère fois.
RE: Onken Caprice
Bonjour Gilles,
Merci pour cet article. Comme j'aime beaucoup l'histoire (et les histoires), il me plaît de lire ce genre de texte datant d'une quarantaine d'années sur un sujet qui me passionne. En effet, je suis très tenté par les compressions Onken. Certes, il s'agit quand même de voir quelques éléments: 1) puis-je espérer une grande amélioration par rapport à une TAD TD-2001? (je ne te pose pas tant la question directement que je la soulève comme questionnement à moi-même); 2) pourrais-je en trouver? et 3) cet achat est-il raisonnable? (vu le prix, c'est un pensez-y bien et cela ramène à la question 1). Il serait certainement apprécié d'écouter des compressions Onken, mais pour le Québec, je ne vois pas qui. Je ne sais même pas si quelqu'un a ça ici.
Dans les derniers jours, j'avais aussi vu que certaines membranes étaient faites de titane, matériaux que j'apprécie pour certaines applications, mais que je ne connais pas pour l'audio. Quant au béryllium, c'est le même matériaux que pour les TD-2001. De ton côté, as-tu les versions titane?
À+
RE: Onken Caprice
Sébastien,
Dans les années 70, après quelques essais, Koïzumi avait décidé d'abandonner le béryllium, difficile à travailler, mécaniquement peu durable dans le temps, et surtout pas adapté aux basses fréquences. Il lui a préféré le titane et toutes ses compressions l'utilisent.
RE: Onken Caprice
Est sur le schéma, un L-Pad et un transformateur de volume situé?
Felix
