Vds 2 Hypex AS2.100 digital - Version imprimable +- MELAUDIA :: forums (https://forums.melaudia.net) +-- Forum : petites annonces (https://forums.melaudia.net/forumdisplay.php?fid=12) +--- Forum : vend (https://forums.melaudia.net/forumdisplay.php?fid=13) +--- Sujet : Vds 2 Hypex AS2.100 digital (/showthread.php?tid=13917) |
Vds 2 Hypex AS2.100 digital - Ivan - 28/10/2025 Amplificateur et DSP Hypex AS2.100 digital - 2x100W + sortie LFE Ce module d'amplification avec filtrage numérique intégré a été conçu pour alimenter des enceintes actives, éventuellement aidées par un caisson actif. Le module de filtrage numérique se contrôle avec le logiciel Hypex DSP Filter Design qui permet d'élaborer les courbes de filtrage que vous souhaitez selon de nombreux paramètres. 200 € la paire + port selon destination ou à prendre aux Ulis zone de courtaboeuf ivan Description issue de la doc Hypex: The “AS2.100” is a plate amp for use in powered speaker systems. As an active speaker controller, a AS2.100 can form the basis of a powerful active two-way monitor. In stereo mode one AS2.100 will power an active master / passive slave pair. Finally, the module may also be used as a one-way 140W amplifier. All signal processing, including volume control, is done using the on-board DSP (digital signal processor). Figure 3 shows the block diagram of the amplifier. When two modules are used, the second unit slaves to the first unit (master) through a link cable. The link cable (a stereo mini jack cable) carries both the right audio channel and control data. This way, both units respond to the master’s control panel. A PC controls the AS2.100 through the USB port. This connection is used to upload the configuration and filter settings. An optional board permits use of the USB link for audio as well as an SPDIF link. In digital mode, master/slave linking is done through the SPDIF in/out connections instead of the mini jack cable RE: Vds 2 Hypex AS2.100 digital - Baoui - 28/10/2025 Bonjour Ivan, Je suis intéressé par la paire. Suite en MP. Xavier |
