Alex Garner of Tannoy in Scotland made the following recommendation for the 12" Monitor Gold. Compact with response to 48Hz- 75 Litres, 2 x 50mm diameter ports, approx 100mm long. Ideally, tune the minimum between the two impedance peaks to 48Hz. Ideal with response to 35Hz- 150 litres, 2 x 100mm diameter ports, approx 200mm long. Ideally, tune the minimum between the two impedance peaks to 35Hz. For 15" monitor gold he recommended 300L with 4 ports of 100mm diameter, 250mm long. That is what I have and am very pleased with. Peter Campbell Australia
