0
True
hor
ver
1
20
24000
True
True
False
True
True
False
False
False
10
False
1000
False
-1000
False
1500
False
-1000
25
2
2
2
2500
0
0
0
20.0
20000.0
85.0
0.0
1
False
False
False
Linkwitz-Riley
4
8500.0
0.7071
False
20.0
20000.0
85.0
0.0
1
False
False
False
Driver #1
80
8
False
1
0
False
False
False
None
g.zma
1
g.frd
0
0
Driver #2
80
8
False
1
-255
False
False
False
None
m.zma
1
m.frd
0
0
Driver #3
80
8
False
1
-310
False
False
False
None
a.zma
1
a.frd
0
0
0
Analog
96000
Generator
3
9
G1
Eg
2.83
V
False
0.01
200
False
Rg
0.001
Ω
False
0.001
1000
False
3
6
3
12
Ground
3
13
False
False
3
12
Driver
33
9
Driver #1
False
False
False
False
False
D1
20.0
20000.0
85.0
0.0
1
False
False
False
20.0
20000.0
0.0
0.0
1
False
False
False
X
0
mm
False
-2000
2000
False
Y
0
mm
False
-5000
5000
False
Z
0
mm
False
-2000
2000
False
R
0
deg
False
-180
180
False
T
0
deg
False
-180
180
False
32
6
32
12
Ground
32
13
False
False
32
12
Driver
33
28
Driver #2
False
False
False
False
False
D2
20.0
20000.0
85.0
0.0
1
False
False
False
20.0
20000.0
0.0
0.0
1
False
False
False
X
0
mm
False
-2000
2000
False
Y
0
mm
False
-5000
5000
False
Z
0
mm
False
-2000
2000
False
R
0
deg
False
-180
180
False
T
0
deg
False
-180
180
False
32
25
32
31
Ground
32
32
False
False
32
31
Driver
33
49
Driver #3
False
False
False
False
False
D3
20.0
20000.0
85.0
0.0
1
False
False
False
20.0
20000.0
0.0
0.0
1
False
False
False
X
0
mm
False
-2000
2000
False
Y
0
mm
False
-5000
5000
False
Z
0
mm
False
-2000
2000
False
R
0
deg
False
-180
180
False
T
0
deg
False
-180
180
False
32
46
32
52
Ground
32
53
False
False
32
52
Inductor
12
6
False
False
False
L1
L
4
mH
False
0.001
100000
False
DCR
0.394
Ω
False
0.01
100
False
Wire
1.4
mm
False
0.1
10
False
9
6
15
6
Capacitor
15
9
False
False
True
C1
C
22
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
15
12
15
6
Ground
15
13
False
False
15
12
Wire
23
6
False
15
6
28
6
32
6
Capacitor
12
25
False
False
False
C2
C
15
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
9
25
15
25
Inductor
15
28
False
False
True
L2
L
3.5
mH
False
0.001
100000
False
DCR
0.4
Ω
False
0.01
100
False
Wire
1.4
mm
False
0.1
10
False
15
31
15
25
Ground
15
32
False
False
15
31
Inductor
18
25
False
False
False
L3
L
0.33
mH
False
0.001
100000
False
DCR
0.13
Ω
False
0.01
100
False
Wire
1.4
mm
False
0.1
10
False
15
25
21
25
Capacitor
21
28
False
False
True
C3
C
2.7
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
21
31
21
25
Ground
21
32
False
False
21
31
Resistor
24
25
False
False
False
R1
R
3.3
Ω
False
0.01
10000000
False
Pow
5
W
False
0.1
1000
False
21
25
27
25
Resistor
27
28
False
False
True
R2
R
10
Ω
False
0.01
10000000
False
Pow
5
W
False
0.1
1000
False
27
31
27
25
Ground
27
32
False
False
27
31
Wire
29
25
False
27
25
32
25
Wire
6
6
False
9
6
6
6
3
6
Capacitor
12
46
False
False
False
C4
C
1
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
9
46
15
46
Inductor
15
49
False
False
True
L4
L
0.12
mH
False
0.001
100000
False
DCR
0.11
Ω
False
0.01
100
False
Wire
1.4
mm
False
0.1
10
False
15
52
15
46
Ground
15
53
False
False
15
52
Capacitor
28
9
False
False
True
C5
C
22
uF
False
0.0001
100000
False
ESR
0.01
Ω
False
0.001
10
False
28
12
28
6
Resistor
28
15
False
False
True
R5
R
6.2
Ω
False
0.01
10000000
False
Pow
5
W
False
0.1
1000
False
28
18
28
12
Ground
28
19
False
False
28
18
Wire
9
15
False
9
25
9
6
Wire
9
35
False
9
46
9
25
Wire
23
46
False
15
46
32
46
