% %================================================================= % SPECTROGRAM PLOT USING WAVELETS % by Jean-Michel Le Cléac'h (version 2011) %================================================================= % choose your own analysis parameters on lines 45 to 49 % clear; clear all; warning off;% %================================================================= % graphic windows positions %================================================================= colordef white; %plots with a white background color width= 700; height = 450; rect=[ 64, 51, width , height ]; set(figure(1),'Position',rect); rect=[ 64, 501, width , height ]; set(figure(2),'Position',rect); rect=[ 210, 501, width , height ]; set(figure(3),'Position',rect); %================================================================= % INPUT OF THE IMPULSE RESPONSE (WAV format) %================================================================= % % next line = the path of the directory where to begin % to look for the pulse response % e.g. : cd('C:\Documents and Settings\JMLC\Bureau'); % %================================================================= % cd('C:\Documents and Settings'); repertoire=uigetdir; cd (repertoire); [nomfichier,nomchemin]=uigetfile('*.wav','choice of a .wav file'); nomchemin;nomfichier; [sig,Fe,Nbits]=wavread([nomchemin nomfichier]); Fe; Nbits; N=length(sig); Te=1/Fe; %================================================================= %================================================================= % SET THOSE PARAMETERS TO DESIRED VALUES fmin=300 ; % lowest frequency limit of the spectrogram (Hz) fmax=20000; % highest frequency limit of the spectrogram (Hz) tmax=0.0045; % upper limit of the time axis of the spectrogram (sec) Nfreqs=300; % number of frequencies displayed on the spectrogram pos=4; % position of the pulse, 1=center...5=on left of the plot %================================================================= %================================================================= pos=round(pos+0.5); Nper=round(0.5+(tmax/Te));Nper=pos*round(0.5+(Nper/pos)); tmax = Te*Nper; if fmax>Fe/2; fmax=Fe/2;end if fmin<20; fmin=20;end freq=logspace(log10(fmin),log10(fmax),Nfreqs); logfreq=log10(freq); % for vertical log axis of the spectrogram iorig=1+((tmax/pos)/Te); t2 = tmax; t1 = t2-(tmax*(1+pos)/pos); tp = t1 : Te : t2; Npts=length(tp); y=zeros(1,Npts); %================================================================= % positionning of the Impulse Response inside the signal window %================================================================= y2=abs(sig); maxabs=max(y2);% imax= find(y2==maxabs); idec= iorig-imax; for i = 1:N; j=round(i+idec); if j>0; if j<=Npts; y(j)=sig(i); end end end %=============================================================== % plot of the centered Impulse response %=============================================================== figure(1);plot(tp,y); axis ([ t1 t2 1.1*min(y) 1.1*max(y)]); title('Impulse Response'); xlabel('time (s)'); %=============================================================== %=============================================================== % MAIN LOOP OF THE SPECTROGRAM %=============================================================== spectro=zeros(Nfreqs,Npts); for i = 1:Nfreqs %=============================================================== % calculation of a gaussian envelop pulse for the ith frequency %=============================================================== fcentr= freq(i); tc = 1.6926/fcentr; tc=Te*round(tc/Te); t = -tc : Te : tc; ye = exp(-t.*t/(1/(2.1437*fcentr*fcentr))); cosgauss = ye .* cos(2*pi*fcentr*t); % In-phase singauss = ye .* sin(2*pi*fcentr*t); % In Quadrature %=============================================================== % convolution of the IR by the wavelet pulse and repositionning %=============================================================== zcos=conv(y,cosgauss); zsin=conv(y,singauss); zcos2 = zcos.*zcos; zsin2 = zsin.*zsin; zamp=zcos2+zsin2; zamp = zamp.^(1/2); long_decal= round((length(t)+0.5)/2); spectro(i, :)=zamp(long_decal:long_decal+Npts-1); end %=============================================================== % spectrogram in dBs %=============================================================== dBmin=-40;%------------------------------- 40 dB color scale specmax=max(max(spectro)); spectro=spectro/specmax; spectro = 20*log10(spectro); spectro=max(dBmin,spectro); %=============================================================== % graphical output of the spectrogram %=============================================================== YT=[40 60 80 100 200 400 600 800 1000 2000 4000 6000 8000 10000]; YT= log10(YT); Ymax= .1*fix(1+max(y)*10.0); Ymin= .1*fix(-1+min(y)*10.0);Ylength =Ymax-Ymin; Yt=linspace(Ymin,Ymax,fix(1+(Ymax-Ymin)/0.1)); figure(2);clf;orient tall;zoom on imagesc(tp,logfreq,spectro); axis xy; colormap(jet(256)); set(gca,'YTick',YT); set(gca,'YTickLabel',{'4','6','8','100','2','4','6','8','1000','2','4','6','8','10000'}) grid on; title('Spectrogram'); xlabel('time (s)');ylabel('frequency'); figure(3);imagesc(tp,logfreq,spectro); axis xy; colormap(jet(256)); colorbar % if a colorbar is needed remove % at beginning of the line figure(2); %=============================================================== % END %===============================================================
