clear,clear all; warning off; Fe=48000; duration=120; % durée du sweep cd('C:\Documents and Settings\JMLC\Mes documents\Audio\cellules'); repertoire=uigetdir; cd (repertoire); [nomfichier,nomchemin]=uigetfile('*.wav','choix d''un fichier .wav'); nomchemin;nomfichier; [signal,Fe,Nbits]=wavread([nomchemin nomfichier]); tic; Fe; Nbits; M=length(signal); %signal=zeros(1,M); signal=signal'; maxsignal=max(abs(signal)); Pow2=nextpow2(M);N=2^Pow2; Fft1=fft(signal,N); %################################################# % lecture du chirp initial [balayage,Fs,Nbits]=wavread(['C:\Documents and Settings\JMLC\Bureau\balayage_.wav']); balayage=balayage'; Fft2=fft(balayage,N); i3=1+round(20* N/48000); for i = 1:i3 % boucle 3 d Fft1(i)=0.0; Fft1(N-i+1)=0.0; end coef=(19900/24000); imid=1+(N/2.0); i3=1+round(coef* N/2.0); i4=(2*imid)-i3; for i = i3:i4 % boucle 3 d Fft1(i)=0.0; end Fft2=Fft1./Fft2; Fft1=ifft(Fft2); pulse = real(Fft1); pulse = fftshift(pulse); if abs(max(pulse))< abs(min(pulse));pulse=-pulse;end pmax=max(pulse); imax=find(pulse==pmax); Lp=2^15; pulc = pulse(imax-Lp : imax+Lp-1); pmax=max(abs(pulc)); pulc=pulc/pmax; figure(1);plot(pulc); pmax=max(abs(pulse)); pulse=pulse/pmax; wavwrite(pulse,48000,16,'C:\Documents and Settings\JMLC\Bureau\pulse.wav') toc
