07/07/2009-18:40:51
VDS convertisseurParasound D/AC-1000 (2x PCM63)
Je vends un convertisseur multibit Parasound D/AC-1000 (2x PCM63)
Prix: 180 euro (livraison inclus)
Specifications
Frequency Response: 2.5 Hz - 20 kHz, +/- 0.25/0.5 dB
Signal to Noise Ratio: > 110 dB, 115 dB typical
Channel Separation: > 100 dB @ 20 kHz
Total Harmonic Distortion: < 0.0025% @ 1 kHz
Amplitude Linearity: > 95 dB; 98 dB typical
Phase Linearity: +/- 0.1¨? @ 20 kHz
Maximum Jitter: < 150 picoseconds RMS
D-A Converters: 20 bit, push-pull, independent for each channel 2x PCM63P-J
Oversampling Rate: 8 X (352.8 kHz)
Digital Input: 32 kHz - 48 kHz, Consumer standard SPDIF
Filters: 8x interpolating digital filter; two 2/3-order low-pass anti-imaging filters
Absolute Polarity: 0 deg or 180 deg switchable
Digital Inputs: Coaxial; TOSlink fiber optic; ST module fiber optic
Outputs: Analog Line Out: 2 V nominal, 600 OE©, suitable load >= 10 k OE©; Digital: 75 OE© RCA coaxial, 0.5 V peak-to-peak
Specifications
"Voici mon secret. Il est très simple: on ne voit bien qu'avec le cœur. L'essentiel est invisible pour les yeux." Antoine de Saint-Exupéry
