Bipolar junction transistor / Transistor Bipolaire
MichelCH
Member
Message : #1
Hello ,
I've got some questions concerning bipolar junction transistor:
* What should be the parameters to check when I sort them (HFE,...) ?
* Do we have to use them in the area where the static current gain(HFE) is maximum ?
* What should be the power where the BJT have to be used (1/5 of maximum power, 1/3) ?
Thanks a lot !
Salut ? tous,
J'avais trois questions qui me trottaient dans l'esprit hier soir:
* Sur quels param?tres doit-on trier les bipolaire( hfe,..???) ?
* Doit-on utiliser pr?f?rentiellement, les bipolaires dans la zone o?? le gain en courant est maximale (hfe max) ?
* Quel devrait ?tre la puissance de fonctionnement pour un Bipolaire de puissance ? (1/5 de la puissance max, 1/3,...)
Merci ? vous tous !
Ce message a été modifié le: 02/04/2009 10:00:40 par MichelCH.
02/04/2009 09:54:16
MichelCH
Member
Message : #2
RE: Bipolar junction transistor / Transistor Bipolaire
Hello all!
If we have a look to the article published in the Audiophile(N?29/1st serie), we see that all Kan?da amp described with different output power have the same quiescent current (500 mA). It seems that Kaneda use the output BJT in the area where the current gain is maximum(HFE ~ 80). Also, we see that the power dissipated is always arount 20 W. Does someone have the datasheet of the 2SD188 or 2SA637 ?
Thanks all !
Ce message a été modifié le: 03/04/2009 09:30:09 par MichelCH.
03/04/2009 09:29:16
stephane
Message : #3
Club double 16"
03/04/2009 12:48:04
MichelCH
Member
Message : #4
Thanks a lot !
03/04/2009 14:09:03
