Pages (304): « Première < Précédente 219 220 221 222 [223] 224 225 226 227 Suivante > Dernière »
Basse-Kanata
Message : #2221
RE: Kits Kaneda
La fil va un peu du coq à l'âne même si nous restons tout à fait dans le sujet Kanéda. Comme je sais que le Kanéda No.224 attire souvent l'attention ici, voici les traductions des deux sommaires d'articles à son sujet (MJ no. 1080 et 1081). Quant à moi, je trouve la traduction du japonais à l'anglais assez bonne.
Bonne lecture,
DC amplifier series No.224
All FET power IVC, SiC SBD rectified power supply integrated type
Equipped with D / A converter
SiC MOS-FET Power IVC [Part 1] Akihiko Kaneda
It is the appearance of the power IVC of AC power version. All FET configuration, built-in DAC, and small size. It will be the best amplifier to make the system simple.
Unlike the conventional configuration, the first stage constant current circuit of the power IVC has a form that fixes the gate of the Nch FET with a Zener diode. If it is a self-bias type of the conventional FET, there was a disadvantage that overcurrent flows at the time of cold start, but there is no fear in this form.
In the initial stage differential stage, cascade connection of 2SK 117 to 2SK 117 differential. The second stage is not a differential form but the current amplifier of 2SJ77. The final stage is Darlington (?) Composition of 2SK 214 and SCT 2080KE.
The biggest difference from amps already announced is that gain IVC has no gain adjustment. Will not this lead to stability of the NFB?
Supply voltage of voltage amplification stage is + 100V, -8V. Power supply voltage of power amplification stage is + 50V / - 50V.
For the transformer, it is TS-180 which was often used in UHC power amplifier. Many people are on hand and it seems to be useful for reuse. The winding for the heater is assigned to the analog part and the digital part of the DAC.
Diode for rectification is SiC Schottky diode of ROHM.
Although it is not specified about the maximum output of this power IVC, it seems that it seems to be a considerable high power amp. If this listening result is good, the way to the AC power amplifier is opened. This AC power amplifier is a nice plan for me who is lazy.
D / A converter installed
SiC MOS-FET power IVC [second part]
It is the production version of SiC power IVC with AC power version DAC built in.
The maximum output was 120 W at 8 Ohm load and 182 W at 4 Ohm load. According to the article, since 196 W is outputted from the amplifier of "Completely Symmetric Audio DC Amplifier" on page 187, if the drive stage is improved, the maximum output power can be expected to increase.
In the audition notation, it is stated as follows.
"The contrast between ff and pp is also surprisingly sharp and the music is lively and active From the standpoint of the audience, real serious sounds that you listen to from the performer's point of view are moving.
The fulfillment feeling of the super low sound common to SiC power IVC has been further increased. So much
Many kinds of instruments support super bass. This sound far exceeds the limit of the speaker. "
Although it is not explicitly written that the power supply voltage rises with AC power supply and the dynamic range has been expanded explicitly, I think that most of the improvement in sound quality of this amplifier is due to AC power supply.
Personally, as loading the DAC near the transformer for the power amplifier does not calm down, I think that it probably will not make it as it is in this production article, but it is probably possible to cut out only the power IVC and make it I thought.
It is nice information for AC power DC amp (?) Fans who intend to decide on lunches like me. With this, I can see the plan to convert the current UHC MOS power amplifier to SiC.
First of all, I'm thinking about replacing the diode of the UHC MOS power amplifier on hand.
12/04/2017 18:27:49
Basse-Kanata
Message : #2222
RE: Kits Kaneda
Maintenant, les deux traductions des sommaires des articles du Kanéda No. 225 dont nous parlons souvent aussi (MJ no. 1082 et 1083). Il s'agit de deux textes extrêmement intéressants, car ils nous permettent de comprendre les améliorations entre le 224 et le 225:
DC Amplifier Series No.225
All FET configuration, 8 Ω load 180 W x 2, 4 Ω load 306 W, SiC rectified power supply
SiC MOS-FET High Power IVC [Part 1] Akihiko Kaneda
It is a system that improves the driver stage as expected. In No. 224 the distortion rate of 10 kHz was worse than that of 1 kHz. The reason for this is that in the source follower configuration of the driver stage, the Rs is too small, the charging current of the last stage Ciss flows to the Rs side, and the teacher analyzes that it is not effectively used. In this machine, we aimed to maximize the effect by decreasing the adverse effect by making Rs larger than before and lowering the power supply voltage to connect Rs.
Although it was originally using 2SK 214 (like), but after submitting the first part of the manuscript, FET for the driver arrived from ROHM, and the driver also suddenly changed to SiC. The model number of the SiC MOS FET for the driver is SCT21201AF. The effect of SiC conversion on the driver stage is phenomenal, music information has increased, expressive power has further improved.
The power supply voltage of the voltage amplification stage was +100 v / - 8 v in the No. 224, but it was +100 v / -100 v in this unit.
The specified transformer is TS - 180C, the winding of the power amplification stage is 44 V 7.8 A x 2. In No. 224, 0.33 Ω was inserted in the series to protect the SiC diode, but this 0.33 Ω was inserted even in No. 225, but UHC MOS for short-circuiting this resistor was added after startup .
When you look at the photos with parts mounted on the case, they are very compact.
It seems to be difficult in space when electrolytic capacitors are set to KMH etc. not specified. It is good that there is a case where the thermal resistance is a little more, there is room in the depth and the height. Because I can open a hole of φ 8 for heat dissipation of the board, this neighborhood seems to be an obstacle to me.
It is introduced that the distortion factor can be improved by changing the constant of the protection circuit of No. 224. In addition, by setting the voltage of the voltage amplification stage to +100 v / -100 v, Rs can be made to have a high resistance to further improve it.
All FET configuration, 8 Ω load 180 W x 2, 4 Ω load 306 W x 2, SiC SBD rectified power supply
SiC MOS-FET High Power IVC [Part 2] Akihiko Kaneda
Details of ROHM's new SiC MOS-FET are announced. The model number is SCTMU001F.
This time it is used for the last stage SCT 2080KE drive, SCTMU001F also has a Pmax of 132 W, Idmax 40 A and it seems to be usable for the final stage of the power amplifier. At a later date, there may be deployment such as the final stage of the battery drive amplifier.
In the meaning of model number, SC stands for silicon carbide, T stands for DMOS-FET, MU for music, 001 for serial number, F means package TO 220AB.
Two types of board diagrams of 2SK 214 and SCTMU001F drivers are posted so that they can be selected considering the availability of parts. Although it is a slight difference, it is nice to be assembled without thinking about extra things.
Although it is a trial record, 2SK 214 drive power IVC is the same tendency as power IVC built in the previous DAC, so it is only for SiC driver. "There is no room to calmly judge the sound, it will be drawn into the music, all the musical tones are beautiful, elegant and artistic." In addition, Mr. Ikuo Tsunoda's listening notes are posted.
Next month will be a hybrid SiC power IVC plan.
12/04/2017 18:48:45
Basse-Kanata
Message : #2223
RE: Kits Kaneda
Suite des traductions de Kanéda
La traduction suivante fait suite à une récente discussion dans laquelle nous parlions d'utilisations de régulateur pour une alimentation donnée.
En août 2013, au sujet du préamp/DAC Kanéda 227, Akihiko Kanéda (est-ce vraiment l'auteur de ces propos?) affirme qu'il a dans cet appareil: "Introduit un régulateur (SiC MOS-FET). Le son semble assez bon avec ou sans le régulateur."
Tout de suite après, il affirme que: "La version avec le régulateur sonne plus naturelle, élégante et rendant un message artistique plein."
Il ajoute: "Subséquemment, quand j'ai découvert cela, je voulais mettre un régulateur dans tous les IVC de puissance."
J'aime bien que Kanéda réfère au rendu du message artistique, car c'est un élément auquel je porte attention lorsque je change un élément dans mon système de son. Cela me semble même un des buts ultimes de la "haute" fidélité.
Par la suite, il a repris ce régulateur dans un ampli de puissance IVC, le Kanéda 232 (128W/8 Ohms).
Ce message a été modifié le: 13/04/2017 04:55:16 par Sébastien.
13/04/2017 00:37:26
gillesni
Grand amateur (87)
Message : #2224
RE: Kits Kaneda
Bonjour Sebastien,
Effectivement, dans notre discussion, nous ne parlions que des amplificateurs, mais le professeur Kaneda utilise bien des régulateurs dans ses préamplificateurs. Il y en a dans le N°227 que j'utilise.
Je n'ai pas eu l'occasion d'écouter, ni de voir le schéma du N°232 dont tu parles, mais je sais qu'il n'en a pas utilisé dans l'amplificateur suivant qui est le N°235, celui avec lequel je suis en train de me bagarrer pour le faire fonctionner correctement.
13/04/2017 12:41:48
Basse-Kanata
Message : #2225
RE: Kits Kaneda
Bonjour Gilles,
Hier, dans mon tour d'horizon des sommaires relatifs aux Kanéda récents, voir ici:
https://blogs.yahoo.co.jp/hsgwhz/folder/...l?m=lc&p=1
J'ai arrêté mes traductions pour les derniers sommaires où je ne trouvais pas de wattage annoncé pouvant témoigner d'un ampli de puissance.
Concernant les régulateurs, certains les préconisent fortement. De mon côté, j'en ai utilisés dans mon préamp à tubes 5687 chargés par transfos de sortie. Ce fut aussi le cas dans mes amplis PSE 300B. Ceci dit, l'alimentation secteur de mon Kanéda 228+, calquée sur celle du 228, me fait croire que ce n'est vraiment pas fondamental dans une conception.
À+
13/04/2017 16:37:38
Basse-Kanata
Message : #2226
RE: Kits Kaneda
gillesni a écrit :
Julien,
Oui, je suis content d'avoir remporté le DAC n°220. Il est pourtant en promo chez Teksanyo...
Bonjour Gilles,
Un ami à moi se cherche un DAC qu'il souhaite utiliser avec de la musique dématérialisée. Est-ce que le Kanéda 220 est un bon candidat pour cette application? Je ne connais rien à ces associations "sans matériau"... Sad
À+
19/04/2017 04:37:55
Basse-Kanata
Message : #2227
RE: Kits Kaneda
En fait, ce n'est pas seulement du dématérialisé qu'il souhaite utiliser, mais du sans fil. Possible avec un DAC Kanéda?
19/04/2017 18:32:02
Dominique-Tanguy
Winterscheid (près Cologne)
Message : #2228
RE: Kits Kaneda
Oui bien sûr, une Chromecast audio par exemple, raccordée au DAC Kaneda (entrėe Spdif avec interface optique ã bricoler). Ça marche bien chez moi.
19/04/2017 18:35:43
Basse-Kanata
Message : #2229
RE: Kits Kaneda
Merci Dominique, j'en informe mon ami.
Sinon, quand tu dis "...entrėe Spdif avec interface optique à bricoler..." on parle de remplacer une prise d'entrée du DAC Kanéda 220 par cela?
Ce message a été modifié le: 19/04/2017 18:54:57 par Sébastien.
19/04/2017 18:48:06
Dominique-Tanguy
Message : #2230
RE: Kits Kaneda
Sėbastien,
La solution est dėcrite ici :
http://forums.melaudia.net/showthread.ph...615&page=4
19/04/2017 19:59:27
